Manage VMware protection groups in NetApp Backup and Recovery
Contributors guillermotome
Create protection groups to manage backup and restore operations for a set of workloads. A protection group is a logical grouping of resources, such as VMs and datastores, that you want to protect together.
You can perform the following tasks related to protection groups:
  • Create a protection group by manually adding VMs to the group or by using VMware vSphere tags.
  • View protection details.
  • Back up a protection group now. Refer to Back up VMware workloads now.
  • Suspend and resume a protection group's backup schedule.
  • Delete a protection group.
Tag-based protection groups
When you choose resources to add to a protection group, you can organize them by datastores, virtual machines, or by vSphere tags.
Tag-based protection using vSphere tags simplifies protection group administration in NetApp Backup and Recovery.
Using tag-based protection has some advantages:
  • When you add a vSphere tag to a VM or datastore in vCenter, that object is automatically included in the next backup for any Backup and Recovery protection group that references that tag.
  • When you remove a vSphere tag from a VM or datastore, that object is automatically excluded from subsequent backups for that tag-based protection group.
  • If a vSphere tag is deleted in vCenter, future backups skip that tag and report a warning.
  • If a VM is migrated to a different datastore, it remains protected as long as it still has the tag that is part of a tag-based protection group.
Tag membership is resolved from vCenter at backup time. Any changes you make to tags in vCenter (adding/removing tags, deleting tags, adding/removing VMs) are automatically reflected in the next backup.
Create a protection group to organize the resources you want to back up and restore together.
Required NetApp Console role
Backup and Recovery super admin or Backup and Recovery backup admin role. Learn about NetApp Console access roles for all services.
Before you begin
  • Ensure your environment is using supported versions of VMware vSphere.
  • When creating a tag-based protection group, ensure the virtual machines and datastores you want to protect are already associated with one or more vSphere tags in vCenter.
  • For VMware workloads, the scheduled backup time uses the time zone of the management host. Refer to Create and manage VMware backup policies in NetApp Backup and Recovery for more information.
Steps
  1. From the NetApp Backup and Recovery menu, select Inventory.
  2. Select a workload to view the protection details.
  3. Select the Actions icon Actions option > View details.
  4. Select the Protection groups tab.
  5. Select Create protection group.
  6. Provide a name for the protection group, and choose how you want to add resources to the protection group. You can add resources organized by Datastores, Virtual machines, or Tags.
    Important Mixing resource types (for example, combining tags with individual VMs or datastores in the same protection group) is not supported.
  7. From the list that appears, select the resources that you want to include in the protection group.
    You can filter the available resources in the list by selecting a specific vCenter or datacenter. Selected resources appear in the list to the right.
  8. When finished, select Next.
  9. Choose how the protection group handles VMs whose virtual disks span multiple datastores:
    • Always exclude all spanning datastores: The protection group will only include datastores that are added to it directly, along with the primary datastore of any VMs added directly to the protection group.
    • Always include all spanning datastores: The protection group will include all datastores spanned by the included VMs.
    • Manually select the spanning datastores to be included: If you select this option, you need to manually select which spanning datastores to include in the protection group from the list that appears. This selection is static; you must update the list of spanning datastores each time new VMs are added to the group.
  10. Select Next.
  11. Select the protection policy that you want to apply to the protection group.
    To create a new policy, select Create new policy and follow the prompts. Refer to Create policies for more information.
  12. Select Next.
  13. Review the configuration.
  14. Select Create to create the protection group.
Suspend a protection group's backup schedule
Suspend a protection group to pause its scheduled backups.
The protection status changes to "Under maintenance" when you suspend a protection group. You can resume the backup schedule at any time.
Steps
  5. Select the Actions icon Actions option > Suspend protection group.
  6. Review the confirmation message and select Suspend.
Resume a protection group's backup schedule
Resuming a suspended protection group restarts the scheduled backups for the protection group.
The protection status changes from "Under maintenance" when you suspend a protection group to "Protected" when you resume it. You can resume the backup schedule at any time.
Steps
  5. Select the Actions icon Actions option > Resume protection group.
  6. Review the confirmation message and select Resume.
Result
The system validates the schedules and changes the protection status to "Protected" if the schedules are valid. If the schedules are not valid, the system displays an error message and does not resume the protection group.
Edit a protection group
Edit a protection group to change its name or settings. You might want to edit a protection group if the resources in the group have changed.
Steps
  5. Select the protection group that you want to edit.
  6. Select the Actions icon Actions option > Edit.
    The Edit protection group wizard guides you through the settings in the protection group.
  7. Make any necessary changes on each screen of the wizard.
  8. When finished, select Submit.
Apply an updated vCenter time zone to an existing protection group
Scheduled backups use the vCenter Server time zone that is recorded when the protection group's schedule is created. If you change the vCenter Server time zone, existing protection groups continue to run on their original time zone (typically UTC) until you update their schedules.
Note Schedules are only re-created when you modify the protection group name, add or remove a VM, change the assigned policy, or update pre/post scripts. Saving without any changes will not update the schedules. This schedule update is a one-time action per protection group and does not start an immediate backup.
Steps
  1. Refresh the vCenter server so its current time zone is retrieved.
  2. Edit the protection group and change its name to a different value, then save.
When you delete a protection group, you remove it and all backup schedules for the group. Delete a protection group if you no longer need it.
Steps
  5. Select the protection group that you want to delete.
  6. Select the Actions icon Actions option > Delete.
  7. Review the confirmation message about deleting the associated backups and confirm the deletion.
