Discover ONTAP systems and volumes without activating NetApp Backup and Recovery
Contributors guillermotome
Discover ONTAP systems and volumes before you activate NetApp Backup and Recovery. After discovery, you can review the volumes, but you can't protect them until you activate Backup and Recovery.
Steps
  1. Go to Protection > Backup and Recovery.
  2. Select the Volumes tile.
    The Volumes dashboard appears.
  3. Select Discover systems.
  4. In the list, select all systems whose volumes you want to discover.
  5. Select Discover.
  6. In NetApp Backup and Recovery, select Inventory.
    The discovery process begins. You can see the status and result of discovery in the Job Monitor.
