Migrate Search and Restore catalog storage to ONTAP NFS
Contributors guillermotome
To improve Search and Restore performance in a NetApp Console local deployment, migrate the catalog index storage from the cluster's default storage class to an ONTAP-backed NFS share. The catalog index supports Search and Restore, and ONTAP-backed NFS can provide measurable performance improvements.
Before you begin
Ensure you have the following before you start:
  • A configured ONTAP NFS StorageClass in the cluster and sufficient capacity on the ONTAP system.
  • Cluster admin credentials with permissions to get, create, apply, exec, patch, scale, and delete resources.
  • A validated backup of the data in the source PVC (take a snapshot or copy it elsewhere before migrating).
Scale down the workers
List the worker deployments and scale each to zero replicas.
  1. List all catalog worker deployments:
    kubectl get deploy -n cbs -o name | grep '/cloudmanager-cbs-catalog-worker-'
  2. Scale every worker deployment down to zero replicas:
    for d in $(kubectl get deploy -n cbs -o name | grep '/cloudmanager-cbs-catalog-worker-'); do
      kubectl scale "$d" --replicas=0 -n cbs
    done
  3. Confirm no worker pods remain:
    kubectl get pods -n cbs | grep cloudmanager-cbs-catalog-worker- || echo "no worker pods running"
Mount the ONTAP volume on NetApp Console local deployment and copy data from the pod
  1. Mount the ONTAP NFS export on a local mount point in the VM created when the NetApp Console local deployment OVA was deployed.
  2. Copy the data from the running coordinator pod into the ONTAP mount, with no intermediate directory. The coordinator must still be running.
    Note Copy the contents into the volume root — not into a sub-directory. The ONTAP volume is the new /opt/netapp/cbs/catalog/shared directory. The data must sit at the volume root so the app finds it at the same paths (e.g. /opt/netapp/cbs/catalog/shared/cbs/<DATASET_NAME>/…​). The tar command format in the following commands streams the directory contents (including dotfiles) into the mount root, avoiding a nested shared folder.
  3. Mount the ONTAP NFS export at a local mount point on NetApp Console local deployment. Use the same server/path you will later use in pv.yaml:
    sudo mkdir -p /mnt/ontap_nfs_vol
    sudo mount -t nfs 10.x.x.x:/my_nfs_vol /mnt/ontap_nfs_vol   # ONTAP SVM data LIF IP : junction path
  4. Copy the pod's shared volume to the ONTAP mount location:
    POD=$(kubectl get pod -n cbs -l app=cloudmanager-cbs-catalog -o jsonpath='{.items[0].metadata.name}')
    kubectl exec -n cbs "$POD" -- tar cf - -C /opt/netapp/cbs/catalog/shared . \
      | sudo tar xf - -C /mnt/ontap_nfs_vol
  5. Set ownership to match the pod identity:
    sudo chown -R 10001:10001 /mnt/ontap_nfs_vol
  6. Verify the data was copied to the volume root (you should see the "cbs" folder directly under the mount, not a nested "shared/"):
    ls -la /mnt/ontap_nfs_vol
  7. Verify the copy and then unmount (the pod will mount it via the PVC later):
    sudo umount /mnt/ontap_nfs_vol
  8. Scale down the coordinator. For example:
    kubectl scale deployment cloudmanager-cbs-catalog --replicas=0 -n cbs
    kubectl rollout status deployment/cloudmanager-cbs-catalog -n cbs
Delete the old PVC and PV
  1. Capture information about the bound PV and then delete the old PVC and PV:
    PV=$(kubectl get pvc cloudmanager-cbs-catalog-shared-pvc -n cbs -o jsonpath='{.spec.volumeName}')
    kubectl delete pvc cloudmanager-cbs-catalog-shared-pvc -n cbs
    kubectl delete pv "$PV"
Create the static ONTAP PV and PVC
  1. Create the following PV and PVC YAML objects:
    pv.yaml
    apiVersion: v1
    kind: PersistentVolume
    metadata:
      labels:
        volume: ontap-nfs-share # Used by the PVC selector to find this exact volume
    spec:
      capacity:
        storage: 50Gi # Match or remain under the actual ONTAP volume size
      volumeMode: Filesystem
      accessModes:
        - ReadWriteMany # Allows multiple Pods to share the NFS mount
      persistentVolumeReclaimPolicy: Retain # Retains ONTAP data if the PVC is deleted
      storageClassName: "" # Leave blank for manual/static provisioning
      nfs:
        server: 10.x.x.x # Replace with your ONTAP SVM data LIF IP address
        path: /my_nfs_vol # Replace with your ONTAP junction path
    pvc.yaml
    apiVersion: v1
    kind: PersistentVolumeClaim
    metadata:
      annotations:
        "helm.sh/resource-policy": keep
    spec:
      accessModes:
        - ReadWriteMany # Must match the PV's access mode
      resources:
        requests:
          storage: 50Gi # Must be <= the PV capacity (50Gi)
      storageClassName: "" # Explicitly matches the empty StorageClass on the PV
      selector:
        matchLabels:
          volume: ontap-nfs-share # Forces binding to the specific PV above
  2. Apply the YAML objects by applying the PV first and then the PVC (the PV must exist for the PVC's label selector to bind to). Then verify that the PVC claim is bound:
    kubectl apply -f pv.yaml
    kubectl apply -f pvc.yaml -n cbs
    kubectl get pvc cloudmanager-cbs-catalog-shared-pvc -n cbs   # expect STATUS: Bound
  3. Scale the coordinator up to 1 replica:
    kubectl scale deployment cloudmanager-cbs-catalog --replicas=1 -n cbs
  4. If you manually scaled workers down and they were not automatically torn down, manually scale them
    back up (this might not be needed, as workers are normally provisioned automatically):
      kubectl scale "$d" --replicas=1 -n cbs
    done
  5. Verify mount and data status. Ensure that the data is present and owned by the user and group 10001:10001:
    kubectl exec -n cbs "$POD" -- mount | grep /opt/netapp/cbs/catalog/shared
    kubectl exec -n cbs "$POD" -- ls -la /opt/netapp/cbs/catalog/shared
Note
  • Reclaim policy Retain: deleting the PVC will not erase the ONTAP data; the released PV must be cleaned up manually if you ever reprovision.
  • Keep Helm in sync: because the PVC is normally rendered by the chart, a future helm upgrade might try to recreate or modify it. To keep this manual ONTAP PVC, point the chart at the same values (storageClass: "", matching size/access mode) or exclude the shared PVC from the release.
  • If you manually run helm uninstall and then try to reinstall, the PV will be installed with the same name and cause a naming conflict.
