Supported Azure archive access tiers with NetApp Backup and Recovery
Contributors guillermotome
Use this information to understand the Azure archive tier that NetApp Backup and Recovery supports. You can also review restore costs and retrieval times for archived backups.
Supported Azure Blob access tiers for NetApp Backup and Recovery
When backup files are initially created, they're stored in the Cool access tier. This tier is optimized for storing data that's infrequently accessed, but it can be accessed immediately when needed.
If your source clusters are running ONTAP 9.10.1 or greater, you can choose to tier backups from Cool to Azure Archive storage after a certain number of days (typically more than 30 days) for further cost optimization. Data in this tier can't be accessed immediately when needed, and will require a higher retrieval cost, so you need to consider how often you may need to restore data from these archived backup files. See the section on this page about restoring data from archival storage.
Note that when you configure NetApp Backup and Recovery with this type of lifecycle rule, you must not configure any lifecycle rules when setting up the container in your Azure account.
Restore data from archival storage
While storing older backup files in archival storage is much less expensive than Cool storage, accessing data from a backup file in Azure Archive for restore operations will take a longer amount of time and will cost more money.
How much does it cost to restore data from Azure Archive?
There are two restore priorities you can choose when retrieving data from Azure Archive:
  • High: Fastest retrieval, higher cost
  • Standard: Slower retrieval, lower cost
Each method has a different per-GB retrieval fee and per-request fee. For detailed Azure Archive pricing by Azure Region, visit the Azure pricing page.
Note High priority is not supported when restoring data from Azure to StorageGRID systems.
How long will it take to restore my data archived in Azure Archive?
There are 2 parts that make up the restore time:
  • Retrieval time: The time to retrieve the archived backup file from Azure Archive and place it in Cool storage. This is sometimes called the "rehydration" time. The retrieval time is different depending on the restore priority you choose:
    • High: < 1 hour
    • Standard: < 15 hours
  • Restore time: The time to restore the data from the backup file in Cool storage. This time is no different than the typical restore operation directly from Cool storage - when not using an archival tier.
    For more information about Azure Archive retrieval options, refer to this Azure FAQ.
Note
Restoring a volume or file from archive storage can take additional time. The job remains In progress in the Job Monitor while Backup and Recovery retries the restore based on the selected priority.
Monitor the restore in the Job Monitor; it completes when the job reaches a final status, such as Completed or Failed, after all retry attempts. Don't start another restore unless the job ultimately fails.
