Supported Google archive storage tiers with NetApp Backup and Recovery
Contributors guillermotome
Use this information to understand the Google Cloud Storage archive tier that NetApp Backup and Recovery supports. You can also review restore costs and retrieval times for archived backups.
Supported Google archival storage classes for NetApp Backup and Recovery
When backup files are initially created, they're stored in Standard storage. This tier is optimized for storing data that's infrequently accessed, but it still allows immediate access.
If your on-premises cluster is using ONTAP 9.12.1 or greater, you can choose to tier older backups to Archive storage in the NetApp Backup and Recovery UI after a certain number of days (typically more than 30 days) for further cost optimization. Data in this tier will require a higher retrieval cost, so you need to consider how often you may need to restore data from these archived backup files. See the section on this page about restoring data from archival storage.
Note that when you configure NetApp Backup and Recovery with this type of lifecycle rule, you must not configure any lifecycle rules when setting up the bucket in your Google account.
Restore data from archival storage
While storing older backup files in Archive storage is much less expensive than Standard storage, accessing data from a backup file in Archive storage for restore operations will take a slightly longer amount of time and will cost more money.
How much does it cost to restore data from Google Archive?
For detailed Google Cloud Storage pricing by region, visit the Google Cloud Storage pricing page.
How long will it take to restore my objects archived in Google Archive?
There are 2 parts that make up the total restore time:
  • Retrieval time: The time to retrieve the backup file from Archive and place it in Standard storage. This is sometimes called the "rehydration" time. Unlike the "coldest" storage solutions provided by other cloud providers, your data is accessible within milliseconds.
  • Restore time: The time to restore the data from the backup file in Standard storage. This time is no different than the typical restore operation directly from Standard storage - when not using an archival tier.
Note
Restoring a volume or file from archive storage can take additional time. The job remains In progress in the Job Monitor while Backup and Recovery retries the restore based on the selected priority.
Monitor the restore in the Job Monitor; it completes when the job reaches a final status, such as Completed or Failed, after all retry attempts. Don't start another restore unless the job ultimately fails.
