Audited NetApp Backup and Recovery actions
Contributors guillermotome
Use this reference to see which NetApp Backup and Recovery actions NetApp Console records on the Audit page. For details about viewing and filtering audit events, see Audit user activity from the Audit page in the NetApp Console documentation.
For each audited action, NetApp Console records the service name, agent, resource, user, and action status.
Audited Backup and Recovery actions
  • Restore volume or files from backup
  • Revert volume to snapshot
  • Start file explore
  • Restore files from snapshot
  • Register cloud credentials
  • Update cloud credentials
  • Delete cloud credentials
  • Create object storage bucket
  • Modify object storage bucket
  • Validate backup migration
  • Migrate backups between ONTAP systems
  • Initialize source protection
  • Peer clusters for protection
  • Initialize target protection
  • Start volume replication
  • Create Cyber Vault system
  • Delete Cyber Vault system
  • Enable Cyber Vault access
  • Disable Cyber Vault access
  • Create ad hoc snapshot
  • Discover volumes and relationships
  • Update application configuration
  • Enable panoramic protection for volumes
  • Modify panoramic protection for volumes
  • Modify object storage for system
  • Create ad hoc cloud backup
  • Initialize protection for system
  • Refresh volume backup metadata (scheduled)
  • Enable backup in a volume
  • Delete ANF snapshot policy
  • Activate panoramic protection in a system
  • Modify panoramic protection in a system
