Error handling in the GraphQL API for Digital Advisor
When the GraphQL server encounters errors while processing an Digital Advisor GraphQL API operation, its response to the client includes an array containing each error that occurred.
Each error in the array has an extensions field that provides additional useful information, including an error code and a message. GraphQL allows for a partial response, with omitted entries logged in the errors array showing a reason and a partial success for updates.
The following is an example error response caused by misspelling the __typename field in a query:
"errors": [
"message": "Cannot query field \"__typenam\" on type \"Query\".",
"extensions": {
"code": "GRAPHQL_VALIDATION_FAILED"
Error codes
GraphQL provides built-in error codes to help categorize different types of errors. For a complete reference of all built-in error codes, refer to the Apollo Server documentation.
In addition to the built-in error codes, the following table shows some additional types of errors:
| Error Code | HTTP Status Code | Description |
BAD_USER_INPUT |
200 |
Invalid value for a field argument |
FORBIDDEN |
200 |
Not authorized due to missing or expired role |
NOT_FOUND_ERROR |
200 |
No record found for the provided input |
UNAUTHENTICATED |
200 |
No token or expired/invalid token |
USER_API_RATE_LIMIT_EXCEEDED |
429 |
Request rate limit exceeded |
Example error responses
The following examples show error responses with their HTTP status codes. GraphQL returns the HTTP status code of 200 as long as the HTTP request is valid and succeeds. Any execution errors are returned inside the JSON response body as shown in the following examples. For more information, refer to Apollo Server documentation.
"errors": [
"extensions": {
"service": "ActiveIQ_GraphQL",
"code": "BAD_USER_INPUT",
"status": 400
"message": "Either start or end date should be present for the given date range."
"data": {
"systems": null
"errors": [
"extensions": {
"code": "FORBIDDEN",
"status": 403
"message": "Access is restricted"
"data": null
"errors": [
"extensions": {
"code": "NOT_FOUND_ERROR",
"status": 404
"message": "No record found!"
"data": null
"errors": [
"extensions": {
"code": "UNAUTHENTICATED",
"status": 401
"message": "Expected a token!"
"data": null
"data": {
"riskAcknowledge": {
"message": "Risk already acknowledged for 1 system(s).",
"status": "partial",
"updatedCount": 1
"errors": [
"extensions": {
"code": "USER_API_RATE_LIMIT_EXCEEDED",
"status": 429
"message": "User API Rate Limit Exceeded."
