Generate your personal access token to use the Digital Advisor APIs
Learn how to generate, use, and revoke a personal access token before using the Digital Advisor APIs. The token ensures that only authorized users and systems can access your NetApp information.
You need to generate tokens before you can use the Digital Advisor GraphQL APIs. The following steps show how to generate a personal access token. If you want to use access and refresh tokens instead, refer to Generate access and refresh tokens.
For information on choosing the token type, refer to Decide whether to use a personal access token or access and refresh tokens.
When you create a token, you choose how long the token is valid (up to a maximum of 90 days).
You can have up to ten active tokens at a time.
The complete token value is only shown at the time you create it.
When a token expires, you can create a new token and update the application that uses it.
Store your token securely, such as in a password manager or secure file.
Never share your token or email it to anyone, and never commit it to source control.
Set reminders to log in and get a new token before your current token expires.
You must have valid NetApp Support Site credentials.
Navigate to Digital Advisor (Active IQ) and sign in using your NetApp Support Site credentials.
In the top navigation bar, select Quick Links, and then select API Services.
Select Register for API access, and then select Register.
Complete the authorization request form, and then select Submit.
Your registration should be approved instantly and activation is automatic. After you are authorized to use the Digital Advisor APIs, you can generate tokens to use when making programmatic API calls. -
After your registration is approved, go back to the API Services page, and select Generate Token.
Select the Personal Access Tokens tab, and then select Create Personal Access Token.
Enter a unique, descriptive token name.
Enter the number of days until expiration. The value must be a whole number from 1 through 90.
Select Generate Token.
Copy the generated token and save it in a secure location. Confirm that you saved it, and then select Done.
You must save the token after it is generated. The complete token value is displayed only at creation. If you select Done before saving the token, revoke that token and create a new one. |
Use your personal access token
The following curl example shows how to use your personal access token in an API request.
curl -X POST https://gql.aiq.netapp.com/graphql \
-H "Authorization: YOUR_PERSONAL_ACCESS_TOKEN" \
-H "Content-Type: application/json" \
-d '{"query": "query getSystems { systems { totalCount cursor systems { serialNumber systemId platformType } } }"}'
Replace YOUR_PERSONAL_ACCESS_TOKEN with the token value you saved when you created the token. Unlike an access token, a personal access token does not need to be refreshed and can be used until it expires or is revoked.
View personal access token information
The Personal Access Tokens tab lists the name, creation date, expiration date, status, and last authenticated date of each token you created. The token value itself is not shown in this list.
Each token has one of the following statuses:
| Status | Description |
Active |
The token authenticates API requests until it expires or you revoke it. |
Expired |
The expiration date has passed and the token no longer authenticates API requests. |
Revoked |
You disabled the token before its expiration date and it no longer authenticates API requests. The list shows the date it was revoked. |
Review the last authenticated date regularly and revoke any token that is unused, unexpected, or no longer required. Revoke a token immediately if you believe it was exposed. |
Revoke a personal access token
The following steps show how you can revoke a personal access token.
From the API Services page, select Generate Token.
Select the Personal Access Tokens tab.
Find the active token you want to disable and select Revoke.
Review the confirmation message and select Revoke Token.
The token is disabled immediately and cannot be re-enabled. Any application using the token loses access to the APIs until you install a new token. |
