Learn about the Digital Advisor MCP server
The Digital Advisor API Model Context Protocol (MCP) server enables compatible AI applications and agents to securely access Digital Advisor information through MCP tools. The server provides tools for discovering systems and customers, reviewing inventory and capacity, identifying risks, retrieving support cases, and accessing AutoSupport information.
To use the Digital Advisor MCP server, you need to register for the Active IQ MCP and Digital Coach Early Access Program. |
Use cases
You can use the Digital Advisor MCP server to:
Find systems, clusters, customers, sites, and watchlists.
Summarize a storage fleet.
Review inventory, contracts, and AutoSupport status.
Analyze current and forecasted capacity.
Identify wellness risks and recommended corrective actions.
Review support cases and Return Merchandise Authorization (RMA) details.
Inspect ONTAP volumes and clusters.
Retrieve AutoSupport messages and section content.
How the MCP server works
The Digital Advisor MCP server is a remote MCP server that uses HTTP.
Your MCP client sends your Digital Advisor personal access token in the Authorization header of each request. The server uses the permissions associated with the token to determine the Digital Advisor information you can access.
