Data queries and mutations in the GraphQL API for Digital Advisor
The Digital Advisor GraphQL API offers flexibility and the ability to define precisely the data you want to fetch.
The two types of allowed operations in Digital Advisor's GraphQL API are queries and mutations. Queries and mutations share similar features, with some important differences.
Queries
GraphQL queries return only the data you specify. In GraphQL, queries operate like REST GET requests. To create a query, you must specify nested subfields until you return only scalar values. The following example query shows how to get system details by including the system object and nested fields to return scalar values for the serialNumber and systemId.
Queries that do not specify nested subfields are invalid. |
query getSystems {
systems {
cursor
totalCount
systems {
serialNumber
systemId
Mutations
In GraphQL, mutations operate like POST, PATCH, and DELETE requests in REST. The mutation name determines which modification is run. To create a mutation, you must specify:
The mutation name. This is the type of modification you want to perform.
The input object. This is the data you want to send to the server, composed of input fields. You pass this as an argument to the mutation name.
The payload object. This is the data you want to return from the server, composed of return fields. You pass this as the body of the mutation name.
The input object in the following example is MutationNameInput and the payload object is MutationNamePayload.
mutation {
MUTATION-NAME(input: {MUTATION-NAME-INPUT!}) {
MUTATION-NAME-PAYLOAD
Variables
Variables can make queries more dynamic and powerful, and they also can reduce complexity when passing mutation input objects.
query($customerId: String) {
system(customerId: $customerId) {
systems {
systemId
serialNumber
variables {
"customerId": "12345"
Use variables in a query
There are three steps required to use variables in your queries.
Define the variable outside the operation in a variables object:
{ variables: { "customerId": "12345" } }The object must be a valid JSON object. This example uses a string variable. You can also define complex types, such as input objects, or multiple variables.
Pass the variable to the operation as an argument:
query($customerId: String) {The argument is a key-value pair, where the key is the name starting with $ (such as
$customerId), and the value is the type (such asString). Add a "!" character to indicate whether the type is required. If you've defined multiple variables, include them here as multiple arguments. -
Use the variable within the operation:
system(customerId: $customerId) {In this example, you use the variable for the customer ID you want to retrieve. You specified a type in step 2 because GraphQL enforces strong typing.
This process makes the query argument dynamic. Variables let you update values without changing the query. You can simply change the value in the variables object and keep the rest of the query the same.
Example query
The following query looks up the customer ID "123", fetches the first 10 systems, and returns each system's system ID, serial number, and capacity information:
query {
systems(customerId: "123", pageSize: 10) {
systems {
serialNumber
systemId
... on ONTAPSystem {
capacity {
logical {
usedKiB
physical {
usedKiB
Example mutation
Mutations often require information that you can only find by performing a query first. This example shows two operations:
A query to find risk instances for a specific risk ID.
A mutation to acknowledge a specific risk on a system.
query {
riskInstances(filter: {
riskIds: ["123"]
cursor
totalCount
riskInstances {
risk {
riskId
system {
serialNumber
systemId
mutation {
riskAcknowledge(acknowledgedBy: 'test-user', riskAcknowledgementFlag: true, justification: 'test acknowledge', riskId: "123", systemKeys: [{ serialNumber: "ABC123"}]) {
message
status
updatedCount
