Digital Advisor API
Use Digital Advisor GraphQL API example queries
Contributors netapp-aoife netapp-yvonneo
After you've generated your tokens and learned how to create a GraphQL request, you can use the example queries to retrieve various types of data from the GraphQL API for Digital Advisor.
Before you use the GraphQL query examples, review the following information:
  • Replace $variableName with actual values or use GraphQL variables.
  • Use cursor-based pagination for better performance with large datasets.
  • Adjust the pageSize based on your application's needs.
  • Include only the fields you need to optimize query performance.
  • Consider using fragments for reusable field sets.
  • Test your queries in the GraphQL Playground or a similar tool before implementation.
For more example GraphQL queries, refer to the Apollo Studio explorer collections.
NetApp inventory management
Learn how to use the example GraphQL queries for NetApp inventory management.
Retrieve a list of sites
You can use this query to fetch a list of site IDs that are to be used in subsequent queries.
Show example
query($customerId: String, $after: String) {
  sites(customerId: $customerId, after: $after, pageSize: 10) {
    cursor
    sites {
      id
      name
Retrieve a list of customers
You can use this query to fetch a list of customer IDs that are to be used in subsequent queries.
Show example
  customers(customerId: $customerId, after: $after, pageSize: 10) {
    customers {
      id
      name
Track all purchased systems
You can use this query to identify which systems are sending telemetry data. This automatically detects gaps in telemetry and for automatic case generation.
Show example
  # Get a summary of AutoSupport status across the fleet
  summary(customerId: $customerId) {
    system
    countByField(countBy: AUTOSUPPORT_STATUS) {
      fieldName
      counts {
        system
  # Fetch systems that are not sending telemetry data
  systems (customerId: $customerId, autoSupportStatus: [OFF, NA, DECLINE, RSS], after: $after, pageSize: 10) {
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      autoSupportConfig {
        autoSupportStatus
View sites and contacts
You can use this query to understand where systems are deployed and who the key contacts are for each location.
Show example
  # Fetch systems along with their site and contact information
  systems(customerId: $customerId, after: $after, pageSize: 10) {
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      site {
        id
        name
        streetAddress
        city
        state
        postalCode
        countryCode
      contactPerson {
        firstName
        lastName
        email
        phone
      sam {
        name
        emailAddress
        managerEmailAddress
      csm {
        name
        emailAddress
        managerEmailAddress
      salesRepresentative {
        name
        emailAddress
        managerEmailAddress
Access the latest configuration details of the system
You can use this query to access the latest configuration details of the system based on its last check-in. This includes a wide range of available attributes including software versions.
Show example
  # Fetch systems with their autosupport configuration details and OS information
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      osType
      osVersion
      platformType
      hardwareModel {
        name
      autoSupportConfig {
        autoSupportStatus
        autoSupportTransport
        isAsupRetransmitEnabled
        isAutoSupportOnDemandCapable
        isAutoSupportOnDemandEnabled
Analyze current and forecasted capacity and storage efficiency
You can use this query to analyze the current and forecasted capacity and storage efficiency for ONTAP, E-Series, and StorageGRID systems.
Show example
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      ... on ONTAPSystem {
        capacity {
          logical {
            usedKiB
            usedSnapshotsKiB
            usedWithoutSnapshotsKiB
            usedSnapshotsAndFlexClonesKiB
            usedWithoutSnapshotsAndFlexClonesKiB
          physical {
            usedKiB
            usedSnapshotsKiB
          reportedOn
          lastAsupId
        monthlyCapacity {
          month
          physical {
            rawMarketingKiB
            utilizationPercentage
          reportedOn
          lastAsupId
      ... on SantricitySystem {
        capacity {
          configured {
            freeKiB
            allocatedKiB
          totalKiB
          unconfiguredKiB
          reportedOn: updatedOn
          lastAsupId
      ... on StorageGrid {
        gridCapacity {
          configured {
            usableKiB
            usedDataKiB
            reservedMetadataKiB
            usedMetadataKiB
          overhead {
            reservedMetadataKiB
          physical {
            actualKiB
            rawMarketingKiB
          reportedOn
          lastAsupId
Discover end-of-support dates for systems, shelves, and disks
You can use this query to proactively plan for future tech refreshes by discovering the end-of-support dates for systems, shelves, and disks.
Show example
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      platformType
      hardwareModel {
        name
        endOfSupport
        endOfAvailability
      techRefreshStatus
        shelvesSummary {
          count
          shelfModuleCount
          endOfSupportDate
          hardwareModel {
            name
            endOfSwSupport
            endOfHwSupport
            endOfAvailability
          moduleHardwareModel {
            name
            endOfSwSupport
            endOfHwSupport
            endOfAvailability
        drivesSummary {
          count
          model
          driveType
          driveModel
          driveCapacityKiB
          endOfSupportDate
Monitor policy variance requests (PVRs)
You can use this query to monitor policy variance requests (PVRs) for your systems along with their expiration dates.
Show example
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      hasPvr
      pvrs {
        id
        info
        validFrom
        validTo
Review contract details
You can use this query to view contract details, including hardware and software contract dates and identifiers.
Show example
    cursor
    totalCount
    systems {
      serialNumber
      systemId
      platformType
      contract {
        expiryDate
        isContractActive
        hardwareContractId
        hardwareContractStartDate
        hardwareContractEndDate
        hardwareWarrantyStartDate
        hardwareWarrantyEndDate
        hardwareServiceLevel
        softwareContractId
        softwareContractStartDate
        softwareContractEndDate
        nrdContractId
        nrdContractStartDate
        nrdContractEndDate
        overallContractEndDate
Support case management
You can use this query to determine which assets have open support cases and their current status.
Show example
  cases(customerId: $customerId, after: $after, pageSize: 10) {
    cursor
    cases {
      caseId
      description
      type
      status
      symptom
      created
      closed
      caseReceivedVia
      priority
      reporterContact {
        userId
        name
      rmaParts {
        numberOfRequestsCreated
        partRequestId
        partRequestItemId
        partRequestItemNumber
        partNumber
        partDescription
        partRequestCreatedDate
        partRequestDeliveryDate
        waybillNumber
      resolution
      lastUpdated
Risk management
Learn how to use the example GraphQL queries for risk management.
Discover and monitor risk
You can use this query to discover and monitor security, upgrade, best practice, configuration, community, and AI issues.
Show example
  # Fetch count of risks for critical and high severity issues
  risksCount (
    filter: {
      severity: [
        CRITICAL
        HIGH
    riskCount
    systemCount
    actionCount
  # Fetch risks for critical and high severity issues
  risks(
    after: $after,
    pageSize: 10,
    filter: {
      severity: [
        CRITICAL
        HIGH
    cursor
    risks {
      riskId
      impactArea
      severity
      shortName
      riskDetail
      mitigationAction
      potentialImpact
      riskInstances {
        system {
          serialNumber
          systemId
          platformType
Receive recommendations
You can use this query to receive actionable recommendations to prevent issues before they occur.
Show example
  # Fetch risks for critical and high severity issues with playbook and corrective action details
  risks(
    after: $after,
    pageSize: 10,
    filter: {
      severity: [
        CRITICAL
        HIGH
    cursor
    risks {
      riskId
      impactArea
      severity
      shortName
      playbook
      correctiveAction {
        url
        displayName
      riskInstances {
        system {
          serialNumber
          systemId
          platformType
Find systems impacted by Common Vulnerabilities and Exposures (CVEs)
You can use this query to list open security risks, the CVEs associated with each risk, and the systems that have that risk. Navigate through the results, keep the risks that list the CVE you need, and sort the systems in your application.
Show example
query SystemsForCve($customerId: String!, $after: String) {
  risks(
    after: $after
    pageSize: 25
    filter: { impactAreas: [SECURITY], isRiskAcknowledged: false }
    cursor
    totalCount
    risks {
      riskId
      shortName
      severity
      potentialImpact
      correctiveAction { displayName url }
      cves { id cvssScore summary description lastUpdated }
      riskInstances(pageSize: -1) {
        riskTriggeredDate
        riskLastTriggeredDate
        systemRiskDetail
        fixedVersions { displayName url }
        system {
          hostName
          serialNumber
          systemId
          osVersion
          platformType
Sustainability and energy management
You can use this query to monitor actual and published power consumption, as well as projected power, heat, and carbon metrics.
Show example
query($siteId: String) {
  # Fetch sites with their carbon emission data
  sites(siteId: $siteId) {
    cursor
    sites {
      id
      name
      carbonEmission {
        emissionFactorPerKwh
        carbonMitigation {
          mitigationPercentage
          modifiedDate
          userModified
        source {
          name
          url
  # Fetch sustainability scores for a specific site
  sustainabilityScore(siteId: $siteId) {
    cursor
    sustainabilityScores  {
      changeFactors
      generatedDate
      percentageChange
      scorePercentage
Upgrade recommendations and history
Learn how to use the example GraphQL queries for upgrade recommendations and history.
Track upgrade recommendations and history
You can use this query to track upgrade recommendations and history, including which systems were upgraded, when, and to which versions.
Show example
  clusters(customerId: $customerId, after: $after, pageSize: 10) {
    cursor
    clusters {
      id
      name
      osUpgradeHistory {
        fromVersion
        toVersion
        postUpgradeAsupId
        postUpgradeAsupGenDate
Retrieve upgrade recommendations
You can use this query to retrieve recommendations on your next upgrade and readiness for upgrade across your NetApp inventory.
Show example
    cursor
    clusters {
      id
      name
      osRecommendation {
        recommendedVersion
        recommendedLatestPatch
        upgradeImageUrl
        upgradeImageUrls {
          upgradeAutomationEncryptedPath
          upgradeAutomationUnencryptedPath
        customUpgradeVersionStates {
          version
          supportState
