SANtricity commands
Activate asynchronous mirroring - SANtricity CLI
Contributors netapp-driley
The activate storageArray feature command activates the Asynchronous Mirroring feature.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Note
This command is only applicable for asynchronous mirroring over Fibre Channel.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
After you activate the asynchronous mirroring feature, you must set up an asynchronous mirror group and an asynchronous mirrored pair.
Syntax
activate storageArray feature=asyncRemoteMirror
None.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
