SANtricity commands
Clear storage array firmware pending area - SANtricity CLI
Contributors netapp-driley
The clear storageArray firmwarePendingArea command deletes a firmware image or NVSRAM values that you have previously downloaded from the pending area buffer.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
Possible damage to the storage array configuration — As soon as you run this command, the contents of the existing pending area in the storage array are deleted.
Syntax
None.
