Clear syslog configuration - SANtricity CLI
The clear syslog configuration command clears the syslog alert information.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
None.
SMcli -n Array1 -c "clear syslog configuration;" SMcli completed successfully.
Minimum firmware level
8.40
