SANtricity commands
Register SNMPv3 USM user - SANtricity CLI
Contributors netapp-driley
The create snmpUser userName command creates a new Simple Network Management Protocol (SNMP) user and registers the new user as a known entity to the SNMP agent. Any attempt to register a new user with the same name and engine ID as that of an existing user is rejected.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
create snmpUser userName="snmpUserName"
    [engineId=(local | engineId)]
    [authProtocol=(none | sha | sha256 | sha512) authPassword="authPassword"]
    [privProtocol=(none | aes128) privPassword="privPassword"]
Parameter Description
userName
The name of the SNMP USM user that you want to create. Enclose the SNMP USM user name in double quotation marks (" ")
engineId
The identifier of the authoritative SNMP engine ID for the user. The value may be "local" to specify the local SNMP agent to be the authoritative agent or a hexidecimal digit string to specify a remote SNMP agent engine ID. The default value is "local".
authProtocol
The authentication protocol (HMAC) to be used for the user. The value may be one of the following:
  • none - No authentication of SNMP messages (default)
  • sha - SHA-1 authentication
  • sha256 - SHA-256 authentication
  • sha512 - SHA-512 authentication
authPassword
The password to be used for authentication for the user. Must be specified if the authentication protocol is "sha", "sha256" or "sha512"
privProtocol
The privacy protocol (encryption) to be used for the user. The value may be one of the following:
  • none - No encryption of SNMP messages (default)
  • aes128 - AES-18 encryption
privPassword
The password to be used for privacy/encryption for the user. Must be specified if the privacy protocol is "aes128".
Minimum firmware level
8.72
