Deactivate synchronous mirroring - SANtricity CLI
The deactivate storageArray feature command deactivates the synchronous mirroring feature, disassembles the mirror repository volume, and releases the controller owner of the secondary volume.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, and E5700 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, or E5700 storage array, you must have the Storage Admin or Support Admin role.
Context
The controller host port that is dedicated to the secondary volume is available for host data transfers.
In previous versions of this command the feature identifier was |
Syntax
deactivate storageArray feature=syncMirror
None.
Minimum firmware level
6.10
