SANtricity commands
Deactivate asynchronous mirroring - SANtricity CLI
Contributors netapp-driley
The deactivate storageArray feature deactivates the Asynchronous Mirroring feature.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
All existing asynchronous mirror groups or asynchronous mirrored pairs must be deleted from the local storage array and the remote storage array before the Asynchronous Mirroring feature can be deactivated.
Syntax
deactivate storageArray feature=asyncRemoteMirror
None.
Minimum firmware level
7.84
