SANtricity commands
Delete certificates - SANtricity CLI
Contributors netapp-driley
The Delete certificates command allows you to delete a certificate from the CLI package trust store.
Supported Arrays
This command applies to the EF600, EF300, EF50, and EF80 storage arrays.
Syntax
delete localCertificate all | alias alias
Parameter Description
alias
Allows you to specify a certificate through the user-defined alias.
Minimum firmware level
8.60
