SANtricity commands
Remove installed external key management certificate - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete storageArray keyManagementCertificate command removes the installed external key management certificate from the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Note
This command applies only to external key management.
Syntax
delete storageArray keyManagementCertificate certificateType=certificate_type
Parameter Description
certificateType
Allows you to specify the certificate type to delete. Valid choices are: client or server.
Example
 SMcli -n Array1 -c "delete storageArray keyManagementCertificate certificateType="client";"
   SMcli completed successfully.
Minimum firmware level
8.40
