Enable storage array feature - SANtricity CLI
The enable storageArray feature file command enables a feature for either a permanent upgrade to the storage array or a trial period.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Context
This command performs one of these actions:
Enables a feature key for a permanent upgrade of a feature
Enables a feature key for a permanent upgrade of a feature pack
Enables a feature for a trial period
A feature pack is a predefined set of several features, such as Storage Partitioning and Synchronous Mirroring. These features are combined for the convenience of the users. When users install a feature pack, all of the features in the feature pack are installed at one time.
Each feature is managed by a license key that is generated for a specific feature or feature pack and a specific storage array. The license key is delivered as a file that you run to apply the license for the feature.
To determine which features are loaded on the storage array run the show storageArray features command. The show storageArray features command lists all of the features installed on the storage array, which features can be evaluated for a trial period, which features are enabled, and which features are disabled.
Syntax to enable a feature key
enable storageArray feature file="filename"
The file parameter identifies the file path and the file name of a valid feature key file. Enclose the file path and the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\dnld\ftrkey.key"
Valid file names for feature key files end with a .key extension.
You will need a feature key file for each feature that you want to enable.
Syntax to enable a feature pack
enable storageArray featurePack file="filename"
The file parameter identifies the file path and the file name of a valid feature pack file. Enclose the file path and the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\dnld\ftrpk.key"
Syntax to enable a feature for a trial period
enable storageArray feature=featureAttributeList
To evaluate a feature for a trial period, you can enter one or more of the following attribute values for the featureAttributeList. If you enter more than one attribute value, separate the values with a space.
driveSecurity
Minimum firmware level
8.25 removes all attributes that are no longer valid.
