SANtricity commands
Remove member volume from consistency group - SANtricity CLI
Contributors netapp-driley
The set consistencyGroup command removes a member volume from an existing snapshot consistency group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Optionally, you can delete the repository volume members from the consistency group.
Syntax
set consistencyGroup ["consistencyGroupName"]
removeCGMemberVolume="memberVolumeName"
[deleteRepositoryMembers=(TRUE | FALSE)]
Parameter Description
The name of the consistency group from which you want to remove a member. Enclose the consistency group name in double quotation marks (" ") inside square brackets ([ ]).
The name of the member volume that you want to remove. Enclose the member group name in double quotation marks (" ").
Determines whether to remove all of the repository members from the consistency group.
Minimum firmware level
7.83
