Resume consistency group snapshot volume - SANtricity CLI
The resume cgSnapVolume command restarts a copy-on-write operation for creating a consistency group snapshot volume that you stopped using the stop cgSnapVolume command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
resume cgSnapVolume ["snapVolumeName"]
cgSnapImage="snapImageName"
| Parameter | Description |
The name of the consistency group snapshot volume that you want to resume. Enclose the name of the consistency group snapshot volume in double quotation marks (" ") inside square brackets ([ ]). |
The name of the snapshot image in a consistency group that you are restarting. The name of a snapshot image is comprised of two parts:
The identifier for the snapshot image can be one of these:
Enclose the snapshot image name in double quotation marks (" "). |
Notes
The name of a snapshot image has two parts separated by a colon (:):
The identifier of the consistency group
The identifier of the snapshot image
For example, if you want to restart a copy-on-write operation for snapshot image 12345, which is in snapshot consistency group snapgroup1 in a consistency group snapshot volume that has the name snapVol1, you would use this command:
resume cgSnapVolume ["snapVol1"] cgSnapImage=["snapgroup1:12345"]
Minimum firmware level
7.83
