SANtricity commands
Resume snapshot volume - SANtricity CLI
Contributors netapp-driley
The resume snapVolume command resumes a snapshot volume operation that was stopped.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
resume snapVolume ["snapVolumeName"] snapImage="snapCGID:imageID"
Parameter Description
snapVolume
The name of the snapshot volume for which you want to resume operations. Enclose the snapshot volume name in double quotation marks (" ") inside square brackets ([ ]).
snapImage
The name of the snapshot image for which you want to resume snapshot volume operations. The name of a snapshot image is comprised of two parts:
  • The name of the snapshot group
  • An identifier for the snapshot image in the snapshot group
The identifier for the snapshot image can be one of these:
  • An integer value that is the sequence number of the snapshot in the snapshot group.
  • NEWEST - Use this option when you want to show the latest snapshot image created in the snapshot group.
  • OLDEST - Use this option when you want to show the earliest snapshot image created in the snapshot group.
Enclose the snapshot image name in double quotation marks (" ").
Notes
The name of a snapshot image has two parts separated by a colon (:):
  • The identifier of the snapshot group
  • The identifier of the snapshot image
For example, if you want to resume snapshot volume operations for snapshot image 12345 in a snapshot group that has the name snapGroup1, you would use this command:
resume snapVolume ["snapVol1"] snapImage="snapGroup1:12345";
To resume snapshot volume operations for the most recent snapshot image in a snapshot group that has the name snapGroup1, you would use this command:
resume snapVolume ["snapVol1"] snapImage="snapGroup1:newest";
Minimum firmware level
7.83
