Save asynchronous mirror group statistics - SANtricity CLI
The save storageArray arvmStats asyncMirrorGroup command saves the synchronization statistics to a file for one or more member volumes in an asynchronous mirror group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
The statistics collected are available only for asynchronous mirror group member volumes in a primary role on the local storage array.
A set of data is collected during the synchronization process that can be used to evaluate how well the mirror configuration is functioning. The data is collected as a set of samples. A sample is created at the beginning of a synchronization process and updated regularly while the synchronization process proceeds.
A sample collects data until the synchronization process completes or until a disruption to the synchronization process occurs, such as a volume ownership transfer or a read-write error. When a synchronization process disruption is resolved (for example, the volume is transferred to the alternate controller), a new sample is created and updated as the synchronization process continues.
Syntax
save storageArray arvmStats asyncMirrorGroup [asyncMirrorGroupName]
arvmStats file="filename"
[volume="volumeName"]
[sampleType=(all | mostRecent | longestSyncTime | errors)]
[recordLimit=(1-90)]
| Parameter | Description |
The name of the asynchronous mirror group for which you are saving synchronization statistics. Enclose the asynchronous mirror group name in square brackets ([ ]). If the asynchronous mirror group name has special characters or numbers, you must enclose the asynchronous mirror group name in double quotation marks (" ") inside square brackets. |
The file path and the file name to which you want to save the synchronization statistics. Enclose the file name in double quotation marks (" "). For example:
This command does not automatically append a file extension to the saved file. You can use any file name, but you must use the |
This parameter is optional. The name of the specific member volume in the asynchronous mirror group for which you are retrieving synchronization statistics. If no volume is specified, the statistics for every member volume in the asynchronous mirror group are saved. If statistics are collected for more than one volume in an asynchronous mirror group, all the data will be written to the same file. Enclose the volume name in double quotation marks (" "). |
This parameter is optional. The default value for
This parameter is optional. The default value for record limit is |
Notes
Statistics are captured for mirrored volumes in the Primary role. The statistics collected include the following data:
Synchronization start time
Synchronization type (manual or periodic)
Synchronization duration
Number of bytes sent
Maximum write time (for a single write)
Minimum write time (for a single write)
Minimum synchronization data rate
Maximum synchronization data rate
Total write time
Repository utilization (%)
Recovery point age
During initial synchronization, statistics samples are captured approximately every 15 minutes.
The synchronization statistics are included in the support bundle.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
