Specify the email (SMTP) delivery method - SANtricity CLI
The set storageArray autoSupport deliveryMethod command sets up the delivery method for sending AutoSupport messages to email (SMTP).
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set storageArray autoSupport deliveryMethod=email
mailRelayServer="serverAddress" senderEmail="emailAddress" destinationAddress="destination1@example.com" destinationAddress="destination2@example.com";
| Parameter | Description | ||
Allows the user to specify the delivery method for AutoSupport collection. Valid choices are:
Allows the user to specify the mail relay server for the AutoSupport collection. |
Allows the user to specify send email address for the AutoSupport collection. |
Email address where AutoSupport dispatches will be sent. This parameter may be provided multiple times to allow dispatches to be sent to multiple addresses. |
SMcli -n Array1 -c "set storageArray autoSupportConfig deliveryMethod=email mailRelayServer=\"mailserver.company.com\" senderEmail=\"user@company.com\";" SMcli completed successfully.
Verification
Send a test message using the start storageArray autoSupport deliveryTest command to verify that your delivery methods are set up correctly.
Minimum Firmware Level
8.40
