SANtricity commands
Set Storage Array Host I/O Protocol - SANtricity CLI
Contributors netapp-driley
The set storageArray hostIoProtocol command configures the host I/O protocol at the storage array level.
Supported Arrays
This command applies to an individual EF50 or EF80 storage array, as long as all SMcli packages are installed.
Roles
To execute this command on an EF50 or EF80 storage array, you must have the Support Admin role.
Syntax
set storageArray hostIoProtocol={"FC" | "ISCSI" | "ISER" | "nvmeIb" | "nvmeFc" | "nvmeRoce" | "nvmeTcp" | "SAS" | "SRP"}
Parameter
Parameter Description
Allows you to specify which host I/O protocol to use for your storage array. Valid choices are: FC, ISCSI, ISER, nvmeIb, nvmeFc, nvmeRoce, nvmeTcp, SAS, or SRP.
Minimum firmware level
12.00
