Set storage array user session - SANtricity CLI
The set storageArray userSession command allows you to set a timeout in System Manager, so that users' inactive sessions are disconnected after a specified time.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Use this command to perform one of these operations:
Set a timeout in seconds for user sessions. The minimum timeout value is 900 seconds (15 minutes).
Turn off session timeouts by setting the value to 0.
None.
Syntax
set storageArray userSession sessionTimeout=n
Minimum firmware level
8.41
