SANtricity commands
Show array label - SANtricity CLI
Contributors netapp-driley
The Show array label command returns information about whether a storage array label has been defined or all existing storage array labels.
Supported Arrays
This command applies to the EF600, EF300, EF50, and EF80 storage arrays.
Syntax
show storageArrayLabel label userDefinedString
show storageArrayLabel all
Parameter Description
userDefinedString
Allows you to specify a user-defined label for the storage array.
Minimum firmware level
8.60
