Show audit log configuration - SANtricity CLI
The show auditLog configuration command shows the audit log configuration settings for the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
None.
SMcli -n Array1 -c "show auditLog configuration;" Logging level: All Full policy: Overwrite Maximum records: 30,000 count Warning threshold: 90 percent SMcli completed successfully.
Minimum firmware level
8.40
