Show certificates - SANtricity CLI
The Show certificates command allows you to view the certificates installed on the CLI package trust store.
Supported Arrays
This command applies to the EF600, EF300, EF50, and EF80 storage arrays.
Syntax
show localCertificate all | alias alias
| Parameter | Description |
Allows you to specify a certificate through the user-defined alias. |
Minimum firmware level
8.60
