Show check volume parity job - SANtricity CLI
The show check volume parity job command shows a specified check volume parity job and the job's status.
Supported Arrays
This command applies to any individual storage array, including the EF600, EF300, EF50, and EF80 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600, EF300, EF50, and EF80 storage array, you must have the Storage Admin role.
Syntax
show check volume parity job jobId=<job_id>;
| Parameter | Description |
The check volume parity job id. This value is required. |
Minimum firmware level
11.80
