Show check volume parity jobs - SANtricity CLI
The show check volume parity jobs command shows all check volume parity jobs and their status.
Supported Arrays
This command applies to any individual storage array, including the EF600, EF300, EF50, and EF80 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600, EF300, EF50, and EF80 storage array, you must have the Storage Admin role.
Syntax
show check volume parity jobs;
None
Minimum firmware level
11.80
