SANtricity commands
Show controller - SANtricity CLI
Contributors netapp-driley
The show controller command returns information about a controller.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
For each controller in a storage array, this command returns the following information:
  • The status (Online or Offline)
  • The current firmware and NVSRAM configuration
  • The pending firmware configuration and NVSRAM configuration (if any)
  • The board ID
  • The product ID
  • The product revision
  • The serial number
  • The date of manufacture
  • The cache size or the processor size
  • The date and the time to which the controller is set
  • The associated volumes (including the preferred owner)
  • The Ethernet port
  • The physical disk interface
  • The host interface, which applies only to Fibre Channel host interfaces
Syntax
show (allControllers | controller [(a|b)])
 [summary]
Parameter Description
allControllers
The setting to return information about both controllers in the storage array.
controller
The setting to return information about a specific controller in the storage array. Valid controller identifiers are a or b , where a is the controller in slot A, and b is the controller in slot B. Enclose the controller identifier in square brackets ([ ]).
summary
The setting to return a concise list of information about both controllers in the storage array.
Notes
The following list is an example of the information that is returned by the show controller command. This example only shows how the information is presented and should not be considered to represent best practice for a storage array configuration.
Controller in slot A
   Status: Online
   Current configuration
      Firmware version: 96.10.21.00
         Appware version: 96.10.21.00
         Bootware version: 96.10.21.00
      NVSRAM version: N4884-610800-001
   Pending configuration
      Firmware version: Not applicable
         Appware version: Not applicable
         Bootware version: Not applicable
      NVSRAM version: Not applicable
      Transferred on: Not applicable
   Board ID: 4884
   Product ID: INF-01-00
   Product revision: 9610
   Serial number: 1T14148766
   Date of manufacture: October 14, 2006
   Cache/processor size (MB): 1024/128
   Date/Time: Wed Feb 18 13:55:53 MST 2008
   Associated Volumes (* = Preferred Owner):
      1*, 2*, CTL 0 Mirror Repository*, Mirror Repository 1*,
      JCG_Remote_MirrorMenuTests*
   Ethernet port: 1
      MAC address: 00:a0:b8:0c:c3:f5
      Host name: ausctlr9
      Network configuration: Static
      IP address: 172.22.4.249
      Subnet mask: 255.255.255.0
      Gateway: 172.22.4.1
      Remote login: Enabled
   Drive interface: Fibre
      Channel: 1
      Current ID: 125/0x1
      Maximum data rate: 2 Gbps
      Current data rate: 1 Gbps
      Data rate control: Switch
      Link status: Up
      Channel: 2
      Current ID: 125/0x1
      Link status: Up
      Channel: 3
      Current ID: 125/0x1
      Link status: Up
      Channel: 4
      Current ID: 125/0x1
      Link status: Up
   Host interface: Fibre
      Port: 1
      Current ID: Not applicable/0xFFFFFFFF
      Preferred ID: 126/0x0
      NL-Port ID: 0x011100
      Link status: Up
      Topology: Fabric Attach
      World-wide port name: 20:2c:00:a0:b8:0c:c3:f6
      World-wide node name: 20:2c:00:a0:b8:0c:c3:f5
      Part type: HPFC-5200    revision 10
      Port: 2
      Link status: Up
      World-wide port name: 20:2c:00:a0:b8:0c:c3:f7
When you use the summary parameter, the command returns the list of information without the drive channel information and the host channel information.
The show storageArray command also returns detailed information about the controller.
Minimum firmware level
5.43 adds the summary parameter.
