Show drive channel statistics - SANtricity CLI
The show driveChannel stats command shows the cumulative data transfer for the drive channel and error information.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
If the controller has automatically degraded a drive channel, this command also shows interval statistics. When you use this command, you can show information about one specific drive channel, several drive channels, or all drive channels.
Syntax
show (driveChannel [(1 | 2 | 3 | 4 | 5 | 6 | 7 | 8)] |
driveChannels [1 2 3 4 5 6 7 8] |
allDriveChannels) stats
| Parameter | Description |
The identifier number of the drive channel for which you want to show information. Valid drive channel values are Use this parameter when you want to show the statistics for only one drive channel. |
The identifier numbers of several drive channels for which you want to show information. Valid drive channel values are Use this parameter when you want to show the statistics for more than one drive channel. |
The identifier that selects all of the drive channels. |
Notes
None.
Minimum firmware level
6.10
7.15 adds an update to the drive channel identifier.
