Show snapshot group - SANtricity CLI
The show snapGroup command returns information about one or more snapshot image groups.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
show (allSnapGroups | snapGroup [snapGroupName] |
snapGroups ["snapGroupName1" ... "snapGroupNamen"])
[summary | schedule]
| Parameter | Description |
The parameter to return information about all of the snapshot groups in the storage array. |
The name of the snapshot group for which you want to retrieve information. Enclose the snapshot group name in square brackets ([ ]). If the snapshot group name has special characters or numbers, you must enclose the snapshot group name in double quotation marks (" ") inside square brackets. |
The names of several snapshot groups for which you want to retrieve information. Enter the names of the snapshot groups using these rules:
If the snapshot group names have special characters or consist only of numbers, enter the names using these rules:
The parameter to return a concise list of information about the snapshot groups. |
The parameter to return a concise list of information about the schedules for the snapshot group copy operations. |
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
This command returns snapshot group information as shown in this example:
SNAPSHOT GROUP DETAILS SNAPSHOT GROUPS----------------------------- SUMMARY
Total Snapshot Groups: 1
Total Snapshot Images: 0
Enabled Snapshot Image Schedules: 0
Status: 1 Optimal, 0 Non Optimal
Name Type Status Associated Base Volume
2_SG_01 Standard Optimal 2
Total Repository Capacity Available Repository Capacity Snapshot Image Limit
10.318 GB 10.318 GB (100%) 0
Snapshot Images Scheduled
0 No
DETAILS
Snapshot Group "2_SG_01"
Status: Optimal
Type: Standard
Associated base volume: 2
Cluster size: 65,536 bytes
Repository
Total repository volumes: 3
Aggregate repository status: Optimal
Total repository capacity: 10.318 GB
Used capacity: 0.000 MB (0%)
Available repository capacity: 10.318 GB (100%)
Repository full policy: Auto-purge Snapshot Images
Utilization alert threshold: 75%
Snapshot images
Total Snapshot images: 0
Auto-delete Snapshot images: Disabled
Snapshot image schedule: Not Applicable
Minimum firmware level
7.83
