Show SNMP MIB II system group variables - SANtricity CLI
The show snmpSystemVariables command returns information about the Simple Network Management Protocol (SNMP) system variables. The system variables are maintained in a Management Information Base II (MIB-II) database.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin or Storage Monitor role.
Syntax
None.
Notes
This command returns SNMP system variables information similar to this example.
SYSTEM VARIABLES
Sys Name: NONE
Sys Contact: NONE
Sys Location: NONE
Minimum firmware level
8.30
