Show storage array DBM database - SANtricity CLI
The show storageArray dbmDatabase command retrieves and shows metadata for the on-board backup locations of a storage array. When there are multiple backup locations, metadata is shown for each location.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
None.
Notes
This command returns the configuration database information in a format similar to this example.
Configuration Database MetadataLast Host Backup: <date stamp>
| CTL | LOCATION | REVISION | ID | GEN NUMBER | STATUS | ACCESS MODE |
A |
Cache |
X.Y |
999999 |
999999 |
R/W |
Optimal |
B |
Cache |
X.Y |
999999 |
999999 |
R/W |
Optimal |
N/A |
Disk |
X.Y |
999999 |
999999 |
R/W |
Optimal |
Minimum firmware level
7.83
