Show certificate revocation check settings - SANtricity CLI
The show storageArray revocationCheckSettings command allows you to view the certificate revocation settings for the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
None.
Syntax
Example
SMcli -n Array1 c "show storageArray revocationCheckSettings;" Revocation Checking: Disabled OCSP Responder Server URL: https://ocspResponderURL.com SMcli completed successfully.
Minimum firmware level
8.42
