Show string - SANtricity CLI
The show textstring command shows a string of text from a script file. This command is similar to the echo command in MS-DOS and UNIX.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
show "textString"
None.
Notes
Enclose the string in double quotation marks (" ").
Minimum firmware level
6.10
