Test alerts - SANtricity CLI
The SMcli alertTest command sends out a test alert to the Windows Event Log and all configured syslog receivers.
Supported Arrays
This command applies only to the E2700 and E5600 storage arrays.
Context
This command is an SMcli command, not a script command. You must run this command from a command line. You cannot run this command from the script editor in the storage management software |
Syntax
SMcli -alertTest
None.
Minimum Firmware Level
7.83
