Test external key management communication - SANtricity CLI
The start storageArray externalKeyManagement test command uses the configured credentials (certificates, address of the KMIP server, and the KMIP port number) to verify that the storage array is able to communicate with the external KMIP server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700,EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
This command applies only to external key management. |
Syntax
None.
Notes
The following example shows the output of the command when the storage array is able to communicate with the external key management server. The output includes the status of the key management server, client certificate, and server certificate.
Key servers configured:
C:\Users\Administrator\Downloads\SMcli (1)\SMcli-02.00.00.0011\bin>SMcli.bat 10.115.XX.XXX -u admin -p infiniti -k -c "start storageArray externalKeyManagement test;"
Performing syntax check...
Syntax check complete.
Executing script...
SUMMARY:
Key management server:
Server address: ::
Server port: 9003
Local controller status: Connection failure
Alternate controller status: Unknown
Client certificate status: Ok
Server certificate status: Ok
DETAILS:
Unable to communicate with the key management server. To correct the problem, perform the
following steps: 1) Check that the key management server address and port is correct. 2) If
the key management server's address is a domain name, check that both controller's DNS
servers are operational and reachable from the controller given your network configuration.
3) Check that the key management server operational and reachable from the controller given
your network configuration. 4) Once the problem has been found and corrected, re-perform the
communication test between the storage array and key management server to clear the needs
attention state on the array.
Script execution complete.
SMcli completed successfully.
No key servers configured:
Executing script...
No key management servers configured.
Minimum firmware level
8.40
