SANtricity commands
Start storage array iSNS server refresh - SANtricity CLI
Contributors netapp-driley
The start storageArray isnsServerRefresh command initiates a refresh of the network address information for the iSNS server.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
If the DHCP server is marginal or unresponsive, the refresh operation can take from two to three minutes to complete.
Note
This command is for IPv4 only.
Syntax
Parameter
None.
Notes
If you used the set storageArray isnsIPv4ConfigurationMethod command to set the configuration but did not set the configuration to DHCP, running the start storageArray isnsServerRefresh returns an error.
Minimum firmware level
7.10
