Start storage array locate - SANtricity CLI
The start storageArray locate command locates a storage array by turning on the indicator lights for the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Use the stop storageArray locate command to turn off the indicator lights for the storage array.
Syntax
None.
Minimum firmware level
6.10
