Stop drive locate - SANtricity CLI
The stop drive locate command turns off the indicator light on the drive that was turned on by the start drive locate command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
stop drive locate
None.
Minimum firmware level
6.10
