Stop drive channel locate - SANtricity CLI
The stop driveChannel locate command turns off the indicator lights on the drive trays that were turned on by the start driveChannel locate command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
None.
Minimum firmware level
6.10
