Allow remote login
PDF of this doc site
Creating your file...
Your file is ready
Remote login lets users from outside of the local area network start an SSH session and change settings on the controller.
Security risk — For security reasons, enable remote login for use only by technical support. |
Steps
Select Hardware.
If the graphic shows the drives, click Show back of shelf.
The graphic changes to show the controllers instead of the drives.
Click the controller for which you want to enable remote login.
The controller's context menu appears.
Select Change remote login, and confirm that you want to perform the operation.
Results
After technical support is finished troubleshooting, follow this same procedure to disable remote login. Disabling remote login terminates any current SSH sessions and rejects any new login requests.
