Edit syslog servers for alerts
PDF of this doc site
Creating your file...
Your file is ready
You can edit the server address used for receiving syslog alerts.
Steps
Select Settings › Alerts.
Select the Syslog tab.
From the table, select a syslog server address, and then click the Edit (pencil) icon from on the far right.
The row becomes an editable field.
Edit the server address and UDP port number, and then click the Save (checkmark) icon.
Result
The updated server address appears in the table.
