Import trusted certificates for controllers
PDF of this doc site
Creating your file...
After receiving digital certificates from a certificate authority (CA), you can import the certificate chain (intermediate and root) for the controllers.
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
You have generated a certificate signing request (.CSR file) and sent it to the CA.
The CA returned trusted certificate files.
The certificate files are installed on your local system.
This task describes how to upload the trusted certificates for the storage array's controllers.
Select Settings › Certificates.
From the Trusted tab, select Import.
A dialog box opens for importing the trusted certificate files.
Click Browse to select the certificate files for the controllers.
The file names display in the dialog box.
Click Import.
The files are uploaded and validated.
Import the management certificate.
