View imported certificate information
PDF of this doc site
Creating your file...
From the Certificates page, you can view the certificate type, issuing authority, and the valid date range of certificates you previously imported.
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
This task describes how to view information for user-installed or pre-installed certificates.
Select Settings › Certificates.
Select one of the tabs to view information about management certificates for the controllers, trusted certificates, and certificates for a key management server.
Tab Description Array Management
View information about all the server certificates imported for the controllers.
Trusted
View information about all the trusted (root) certificates imported for the controllers. Use the filter field under Show certificates that are… to view either user-installed or pre-installed certificates.
User-installed. Certificates that a user uploaded to the storage array (includes trusted certificates, LDAPS certificates, and Identity Federation certificates).
Pre-installed. Certificates included with the storage array.
Key Management
View information about all the management (signed) certificates imported for an external key management server.
