Learn about SANtricity Remote Storage Volumes
Use the SANtricity® Remote Storage Volumes feature to import data from a remote storage device directly to a local E-Series volume. This feature helps streamline the process for equipment upgrades and provides data migration capabilities to move data from non-E-Series devices to E-Series systems.
Configuration overview
The Remote Storage Volumes feature is available with SANtricity System Manager on selected submodel IDs. To use this feature, you must configure a remote storage system and an E-Series storage system to communicate with each other.
Use the following workflow:
SANtricity Remote Storage Volumes is currently not supported on E4000 systems. |
Find more information
Online help, available in the System Manager user interface or in the SANtricity software doc site.
For additional technical information on the Remote Storage Volumes feature, see the Remote Storage Volumes Technical Report.
